It is currently Thu Aug 21, 2025 7:00 pm
PostPosted: Sat Aug 03, 2013 10:59 am
First name: Alex
Last Name: Takacs
State: Illinois
Im sanding the bottom of my braces in my radius dish, but I notice that I cant quite keep them straight. They always lean a little bit to the side. Is there a way that I can keep the braces straight while shaping the bottom?
PostPosted: Sat Aug 03, 2013 11:06 am
Last Name: Livermore
State: Minnesota
Hold a few of them together while you are sanding
PostPosted: Sat Aug 03, 2013 11:24 am
I use a plane. I mark with a radius template and then do a few at a time with a low angle block plane. Takes a little practice but it works well.
PostPosted: Sat Aug 03, 2013 11:27 am
First name: Raymond
Last Name: Pipkin
I've found two things that help me.
First my brace wood is rarely perfectly vertical grain, so I try to position the brace so that if I rock a little bit, the grain will be closer to vertical. I don't leave them square so have to do some shaving anyway.
Second, when shaping the radius I position the braces on the dish as if it were on the top and mark the radius on both sides with a pencil. Then I shave the curve with a hand plane so I'm close to the line on either side. After that I sand on the dish with small strokes. It seems easier to hold the brace vertical.
PostPosted: Sat Aug 03, 2013 11:38 am
Forget sanding! It's for amateur Guitar makers.
http://www.youtube.com/watch?v=C2Qeh9vjrck
PostPosted: Sat Aug 03, 2013 11:51 am
First name: Raymond
Last Name: Pipkin
Slick!
PostPosted: Sat Aug 03, 2013 12:25 pm
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
Zip/Postal Code: 64081
Too much music and mumbling.But vy quick and efficient way to do it with a LA block plane.
PostPosted: Sat Aug 03, 2013 12:39 pm
I've been clamping mine in a vise but I'll be doing that next time.
PostPosted: Sat Aug 03, 2013 1:14 pm
First name: David
Last Name: Ingalls
City: Ashland
State: OR
Zip/Postal Code: 97520
This works well and is very fast. It sure beats pushing little sticks around on a dish!
PostPosted: Sat Aug 03, 2013 1:32 pm
Last Name: Collins
City: Argyle
State: New York
Zip/Postal Code: 12809
I also use a router jig like Davids.
Works great & the joint is ready to glue.
Make one for all the different radii you use.
Mike Collins
PostPosted: Sat Aug 03, 2013 6:23 pm
I've been using a shim on the sole of my smooth plane for years. It takes only about five minutes to do three or four braces clamped together, and you get a perfect radius every time. I clamp them on their sides on a plywood jig, and shoot them, which keeps everything perpendicular.
I'm sure Mario will check in: he advocates free handing them with a plane. That's good too, but I like the uniform radius I get with the shim. Either way, it's another reason to gain some chops with this most basic hand tool.
PostPosted: Sat Aug 03, 2013 10:19 pm
First name: wes
Last Name: Lewis
City: Garland
State: Tx.
Zip/Postal Code: 75044
router table and jig
MK5acoustics.com
PostPosted: Sat Aug 03, 2013 10:35 pm
I bend mine into the reverse curve (concave) using a jig to hold it in that shape and cut it on the tablesaw, then a swipe with a hand plane and you done. When released from the jig the brace springs into the right shape and is ready to go.
PostPosted: Sun Aug 04, 2013 2:02 am
First name: William
Last Name: Holmwood
City: Brighton
Country: England
I didn't have enough space for a router table so I made this:
Works fine, although I have since made a radius dish which also works.
PostPosted: Sun Aug 04, 2013 7:04 am
I hand plane, then touch up on the sanding dish in the same place it will be glued.
Chuck
PostPosted: Sun Aug 04, 2013 12:27 pm
Last Name: McDonald
City: Okanagan Centre
State: British Columbia
Zip/Postal Code: V4V2H6
Here is my method, very quick and accurate.
Scribe on the radius board, sand on belt sander
Brian
image.jpg[/attachment[attachment=0]image.jpg
PostPosted: Sun Aug 04, 2013 12:44 pm
First name: stan
Last Name: thomison
City: branson
State: mo
Zip/Postal Code: 65616
Country: united states
Reality. No Best way. A lot of ways and they work as noted above. I use a radius jig and run it on my joiner or router table or just make a mark on the brace and freehand it. That works best for me as it keeps the radius from rounding when I try to do it on the abrasive radius dish for good flat gluing surface. But that is what works for me. Others are probably better than I am at using abrasive and not rounding the gluing surface.
I know some who as noted use a tablesaw, and know several who use a bandsaw and just cut to the lines and then clean up on the dish.
My main deal for the rig I use is time and best end result for gluing. I am usually doing 5 tops and backs at a time. Or was when I was building for fun and profit, since I am now really, really retired. Still have to make one for myself someday though.
PostPosted: Sun Aug 04, 2013 1:56 pm
Overhead router, flush bearing router bit, jig (just because that's what I've got) and touch up on dedicated radius forms with sandpaper.
PostPosted: Sun Aug 04, 2013 3:27 pm
First name: Tony
Last Name: C
City: Brooklyn
Laser beams.
Sent from my iPhone using Tapatalk 2
http://www.CostaGuitars.com
PMoMC
PostPosted: Sun Aug 04, 2013 3:35 pm
Nice to hear of someone else using that method - I do the same but just use the plane and skip the saw - only takes a couple of minutes, and you get a cleaner, squarer surface than you're likely to with sanding.
James
PostPosted: Sun Aug 04, 2013 4:54 pm
If you pull a rectangular brace into a holder with spacers at the ends, and trim it flat, what you get is not a circular arc. It's close, and many consider it 'close enough', but technically....
PostPosted: Sun Aug 04, 2013 5:07 pm
Agreed, but it is a nice fair curve.
PostPosted: Sun Aug 04, 2013 5:34 pm
First name: Miguel
Last Name: Bernardo
Country: portugal
Hand plane is good enough for me.
PostPosted: Mon Aug 05, 2013 5:07 am
Last Name: Eaton
City: Lamoine
State: ME
Zip/Postal Code: 04605
Is that really the ultimate goal? Are we aiming for and exact radius of a perfect circle. I agree with Jim in that this method creates a really nice fair curve, which IMO is the ultimate goal. I'm personally not aiming to hit an exact arc of a circle and would rather have something a little more fair than perfectly round. Just think this is a nicer feel and a bit more organic than perfect circles. But this has a lot to do with people's method of building as well. And I'm not sure one way is better than the other, just a personal opinion.
PostPosted: Mon Aug 05, 2013 9:11 am
Does anyone believe it needs to be a circular arc?
James
